Im planning on doing the usual MOT pre-checks later myself.
However, Ive got a question to do with the
Mine are rotten so my plan was to remove them for the MOT and if it passes with minor work
o my main question is, will it pass and drive ok without them? A search on google seems to think it will but though id check first.
Also anything else Id need to check apart the usual rust,lights,tyres,fluids
I haven't got a good enough jack to check all bushes etc but if these fail then I will get the garage to do these anyway.
Also its on rev 2 L plate so what are the rules with regards to emmisions? Im sure it has a standard cat on it but would be interested to know if it would be needed for mot`s in the future.
If it passes with little or no work then my plan is to treat it to all new belts and service
