I have just registered on this forum.
The car has quite a few problems, and i knew this before buying it, but decided to do it anyway and get it into proper shape.
it has the 5th gear pop-out, passanger window not working, oil pressure gauge not working, a rough idle, cracked sunroof, etc.
I decided to tackle the problems on the car one by one, replace parts etc.
The first thing i want to tackle is the rough idle thing as it is very annoying.
Basically when the car starts it sits close to 2.000 rpm in idle which is fine.
I replaced the battery and bought and installed proper spark-plugs.
I tried disconnecting the cable on the side of the t-vis inlet manifold
I can prevent the car from staling by turning the screw that is on the t-vis inlet manifold which increases the idle speed.
Tomorrow I am going to drain/bleed/refill coolant to see if this resolves it as I have heard it can cause a rough idle.
Anyone experienced this before, ideas, suggestions, anything is welcome.
