Hi All,
Just bought myself a japspeed exhaust (decat) for my N/A I like how grumbly it is and when its hot it will have the occasional pop. I was wondering if there is any way or anything I can do to it to make it pop a bit more frequently?
Only reason I ask is my friend has a 1,8 celica cat back exhaust with a 3" rolled tip, the thing is alot quieter but it pops a hell of alot more than mine?
Heat wrap
Also I've heard that you can thread the tip of a sharpened screw into the exhaust tip and it will get exceptionally hot - making pretty flames
It should help, can't say from experience though as my engine went bang shortly after I heat wrapped mine from the block back. I was using a Japspeed mani and mid pipe.
The only other options you've got are to mess with the fueling, add a turbo or use smaller diameter exhaust. I'm guessing you've already de-catted? Obviously that will make a big difference.
Mr.Two wrote:It should help, can't say from experience though as my engine went bang shortly after I heat wrapped mine from the block back. I was using a Japspeed mani and mid pipe.
Did you wrap yours in a certain way? I.e. spraying before wrapping or did you just wrap it all up straight off the bat?
Mr.Two wrote:I just bought tonnes of Titanium wrap off Ebay with stainless cable ties and did the whole lot right up to the first backbox hanger (Nur spec)
That is a great way to lower you power output
I used to pop (more BANG!) by flooring it to around 3-4000RPM, foot of pedal, let it drop to around 2-2500RPM and tap the pedal.
Every tap it was BANG BENG BENG BANG.
Could tap it around 5 times.
This was on my turbo tho, with a 3" NurSpecR, which made extremely loud bangs.
But yea, you could try it. (didn't need my engine/exhaust to be hot before doing this trick)
Ren0W wrote:I used to pop (more BANG!) by flooring it to around 3-4000RPM, foot of pedal, let it drop to around 2-2500RPM and tap the pedal.
Done this myself, decat and SS system is what you want to do it. Im pretty sure it also happens when you run too lean not that its a good thing!
Bob, you clearly have some reasoning behind this, why not explain it rather than just making a terse comment?
I find that when cold if you drop gears without rev-matching then it'll pop more frequently, however if the exhaust is properly warm (maybe 20-30 minutes driving) then you'll get pops and bangs even on upshifts. Or at least I do in the Scoob lol
Rolling down a hill in 2nd at about 45mph will do the trick as well
In theory wrapping the exhaust on an NA car will keep heat in the exhaust gas and increase the scavenging effects from the cylinders, and in effect increase power.
In theory in a turbo charged car, wrapping the exhaust after the turbo will keep heat in the exhaust gas, and as a result increase back pressure on the turbine. This reduces the pressure gradient across the turbine, and will reduce maximum power levels achieved.
In an MR2 however, will wrapping the exhaust of a turbo charged car reduce the temperatures in the engine bay, and so allow colder air to be ingested by the compressor and actually increase power?
Did I stress in theory enough?
Not wanting to getting into the handbag fighting but i've noticed this alot on this forum. Why do you guys jump down bobhatton throat when he gives tuning advice? Maybe not a lot in this particular one but other i've seen.
Not in one of his cheer leaders but i found he has good knowledge on these engines and engines in general
Ok he does go on about Chinese products a little too much but we all have our problems
