Hi
I need to swap over my Clutch slave cylinder for a salvage part. I've heard that bleeding the system can be a nightmare.
Is there a particular method which is preferred? I would prefer to avoid splashing out on a vacuum system.
Many thanks
Bleeding the clutch
Re: Bleeding the clutch
I did mine the other week with a one man bleed kit from halfords. On trade it was about £3 and was so easy to do!
Just used my old Gunsons eazybleed. Took two minutes - what a relief!!
