NA vs Turbo fuel Pumps??
ashley
Post by ashley »
Just getting ready to mock up my fuel tank and I'm checking the pumps I've got, the one on the left came out of my rev3 G limited, and the darker one came out of my rev3 GTS:
Turbo pump (part no 195130 - 0700):
NA Pump (part no 195130 - 0800):
Question: is this a standard turbo pump??
ashley
Re: NA vs Turbo fuel Pumps??
Post by ashley »
Anyone?
vtecpower
Post by vtecpower »
being a denso make i would guess yes
Peter Gidden
Post by Peter Gidden »
0700 is N/A pump.
0800 is Turbo pump.
ashley
Post by ashley »
Cheers Peter - 0700 confirmed as a standard turbo fuel pump :thumleft:
madbasshunter
Post by madbasshunter »
Peter Gidden - SBITS wrote:0700 is N/A pump.
0800 is Turbo pump.
Thanks Peter tells me the fuel pump in the garage is a turbo pump :thumleft:
RyanRs wrote:
Skywalker wrote:explain how the coolant leaves the expansion tank and goes back into the coolant system?
Seriously , you don't know the answer to this? and you call yourself a car mechanic :shock:
ashley
Post by ashley »
0800 is Turbo pump.
Careful mate...Peter may have got his part numbers mixed up there :whistle:
0700 = Turbo pump
0800 = NA pump
Turbo pump is a bit smaller, and is the darker coloured one :thumleft:
madbasshunter
Seller assured me that the rev3 had a turbo pump fitted :roll: and I removed it when I dropped the engine
All I know is it's an 0800 :whistle:
ashley
Post by ashley »
That, my friend, looks like an NA pump :silent:
FWIW I did double check with Peter, it was late at night and he mixed the two part numbers up.
madbasshunter
So James lied to me again ](*,)
Glad I didn't drop the tank and fit it :?
