SELECTING WIRE SIZES FOR USE IN LAMP CIRCUITS
Use only stranded wire, never solid
(household type) wire, in automotive applications.
Wire gauge selection is crucial to the success of a circuit upgrade.
Wire that is too small will create the voltage drop we are trying to avoid.
On the other hand, wire that is of too large a gauge can cause mechanical difficulties due to its stiffness, particularly in pop-up
("hidden") headlamp systems.
The headlamp power circuit ought to use no less than 14-gauge
(2.5 mm2) wire, with 12-gauge
(4.0 mm2) being preferable.
10-gauge
(5.2 mm2) can be used if bulbs of extremely high wattage are to be used, but it's usually overkill.
Be sure to pick a kind that flexes easily if yours is a hidden-headlamp system.
Do not fail to use the large wire size on both sides of the headlamp circuit! Voltage drop occurs due to inadequate grounding, too! you will only sabotage your efforts if you run nice, big wires to the feed side of each headlamp, and leave the weepy little factory ground wires in place.
Most factory headlamp circuits run the too-thin ground wires to the car body.
This is an acceptable ground--barely--on a new car.
As a car ages, corrosion and dirt build up and dramatically increase resistance between the car body and the ground side of the vehicle's electrical system.
It takes little extra effort to run the new, large ground wires directly to the battery Negative
(-) terminal or to the metal housing of the alternator, and this assures proper ground.
