[Mk2] [Turbo] Knocking noise near side rear
mr2_ash
Post by mr2_ash »
Hi all.
Wondering if anyone could shed a little light on a knocking noise that's driving me insane!
Every time I drive over a bumpy surface it makes what I can only describe as a 'boomy' knocking noise - but I can't figure out where it's coming from!
Peter from sbits very kindly replaced my oem struts/top mounts with hsd coilovers and drop links so I know it can't be these - rear anti roll bar bushes also in good condition with no broken brackets etc.
Also gave my exhaust a good wiggle and that's not catching anything either.
Anyone got any ideas?
Ash
going4the1
Re: [Mk2] [Turbo] Knocking noise near side rear
Post by going4the1 »
Could it be the bottom ball joint? Jack the rear up and use a pry bar to look for any slackness
Alasdair Mair
Post by Alasdair Mair »
I have a similar issue with nearside rear corner. I think I have narrowed it down to the bushes on the tie arm from hub to crossmember if that helps?
Marf
Post by Marf »
Dodgy shock, fecked top mount, fecked ball joint.
Get the car in the air and jiggle the wheel, see if you can find some play
Draven
Post by Draven »
I'd say ball joint.. get it up in the air and wiggle like you've never wiggled before..
I've bought some cheapy ball joints before they were bu88ered in about a month. :?
