Box is E153 with LSD.
Is there a spring or something that gets worn out? Or been caused by one of the things I have done?
toecutter wrote:New spring made no difference, and it's that stiff hose wouldn't help.
Only other thing I can think of is if either of the shift arms were bent during engine removal/refitting but don't know how to tell what angle they should be at.
Quigonjay wrote:does the car actually drive fine? goes in too all the gears ok?
bobhatton wrote:Remove the cables from the gearbox and see if you have the same problem, if so it is the cables if not it is the gearbox.
jimGTS wrote:i didnt suggest buying a new spring, but simply to see it was sat correctly.
definitely look at the gear linkages gearbox end in that case.
