well, 2 garage mechanics and a garage owner mechanic later and Im losing the will to support MR2 MK2's
( day of ridicule)
The pivot bolt not only is in theee most inaccesible place, the head is rounded.
Its impossible to get a socket onto it as the inner wing panel
( behind the strut is in the way and even if I do
"crack" the rusted seal we are not certain that the bolt can be removed as panel in the way
All garages said using Heat was a definate NO NO as the car would go up in flames, plus there is limited access to get to it.
Everyone at a loss as to what to do to
"free" up rusted bolt.
( only rusted
/ sticking in the alternator sleeve part) as it moves back and forth on bracket.
Mole Grips
? maybe but no purchase or room.
Grip Bolt sockets
.no room to get a ratchet onto
socket
Weld a
"T
type bar onto bolt head
No Room to get at Mounting Bracket Bolts
.and taking subframne
/ driveshaft out was met with pure laughter and WTF faces
.taking engine out was offered as easirer option.
.but for an alternator
Suggestions please or Offers for a useless MR2 sitting on the drive
So now left with a rounded bolt which is 10 mm away from alt bracket, head rounded and no way of getting it free or out
So basically the car is Scrap for want of one Bolt
Im normally upbeat as a design engineer
, but this has me in utter dismay
