Trying to change alternator,
Its a long thin bolt that threads into other end of
When i pivot alternator the bolt turns with it.
However it is so inaccessible that even if i get Mole grips on it there is minimum purchase.
Heat or cutting
I desperately need help from anyone who can suggest ways to free the bolt and remove it.
The bolt head is approx 10mm form the bracket so not sure if someone has botched its assembly.
BUT any help on how to destroy or free this death bolt will be appreciated.
Also where can i get replacement bolt.
If cant remove bolt cant remove alternator
](./images/smilies/eusa_wall.gif)
