3SGE N/A
MT
215.000 miles
fresh spark plugs NGK BKR7
fresh engine oil
open air filter
Mongoose exhaust
I have failed MOT for the second time due to not passing the emission/smog test.
I must meet 3.5% CO max at idle but it is 4% and sometimes it shoots up even to higher values.
I don't experience abnormale fuel usage, the car comes up to temperature without issues, idle is not bouncy, at stable at 750
Still, the car is running way to rich obviously.
The non-branded garage said it can't be the oxygen sensor, those values were ok.
I made an appointment at Toyota but i'm still trying to figure things out.
So what have I done so far:
Question:
I could understand that a combination of the things above can result into failing emission at idle even though the car is perfectly driveable.
In what order do I have to do the things above and how.
