Central Locking Problems......help please.
david240968
Post by david240968 »
I am having problems with my central locking. Inside the car all works fine, when I press the door lock button both doors lock or unlock exactly as they should. The problem comes when locking from outside with the key. Locking or unlockingwith the key only operates the one lock. So if I lock the drivers door the passenger door is still unlocked. The problem is the same on the other door. When locking I can hear the motor run but nothing when unlocking?
