[Mk2] [Generic] what does this feed to the alternator do?
killerferret666
Post by killerferret666 »
its the one that passes through the 7.5amp ECU-IG feed to the point marked L in the manual.
On the alternator
IG - ignition
L -??
S - ??
Just wondered on the names, seeing as im learning the electrics and dont like not knowing!
Ohh and I know my yellow and black wire is bu88ered in the loom from tests, im just after the names more then anything.
My Blog on Miami GT4 kit car build using MR2 Donor Car
http://miamigt4kitcar.blogspot.co.uk/
twitter for photo's as I'm building -
www.twitter.com/iwanabeaferret
Shmed
Re: [Mk2] [Generic] what does this feed to the alternator do?
Post by Shmed »
From HowStuffWorks
S terminal - Senses battery voltage
IG terminal - Ignition switch that turns the voltage regulator on
L terminal - Closes the circuit to the warning lamp
B terminal - Main alternator output terminal (connected to the battery)
F terminal - Full-field bypass for regulator
January 2014
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
Still in the garage...
Return to “Electrical”
