I have BC racing coil overs
However at higher speeds its a bit vague
Everything was tight on the last check and I plan on having an expert check it over.
Also have new toyo T1R on the rear and word T1R on the front
Any other thoughts?
thomp1983 wrote:toyo's are well known for being twitchy and lacking feel when new there awful till run in and with the road conditions as they are at the minute i wouldn't be surprised if that's your problem.
afaik the rev1 tie rod thing was to do with the way they attach to the subframe, earlier cars the tie rods attached closer to the centre of the subframe compared to later cars so if you didn't change the subframe you probably haven't fitted rev1 tie bars.this image explains it better
chris
ChrisW wrote:I'll second the suggestion that it's the tyres.Your description sounds like what I experienced with brand new 225/50/15 T1Rs.
After about 1000 miles I think they've improved but it still sometimes feels like the back end is squirming around on certain road surfaces.
Ste2 wrote:any advice on breaking them in- seen some say that low tyre pressures are the way to go.
