Ok so im looking at a set of wheels for my mk2 at the moment.
http://mr2.gordaen.com/wt_calc.php
Front Values:
Tire Width: 215
Rear Values:
Tire Width: 245 Sidewall: 35
MR2
Your proposed front wheel will be 6.7 mm farther out than flush
Your proposed front is 0.7 mm into the suspension!
Your proposed rear wheel will be 6.7 mm farther out than flush
Wheel Comparison:
Your proposed front wheel will stick out 41.75 mm farther than your old wheel.
Your proposed rear wheel will stick out 41.75 mm farther than your old wheel.
I will be running these with meister zeta r coilovers with standard arches.
From what I have read I can expect them to perhaps foul the coilovers? and as they protrude the arch can expect them to hit the arches? I of course want none of those things to occur.
Any advice would be much appreciated thanks
