[Mk2] [Turbo] 180mph clocks
bigal
Post by bigal »
Just a quickie that I'm sure someone will have the answer to. I have the 180kmh clocks with a converter fitted on the back which converts the clocks to read mph, the question is does it also make the mileage read in miles or does it still count in kilometres?
Davsurfa
Re: [Mk2] [Turbo] 180mph clocks
Post by Davsurfa »
The convertor slows the feed to circuit board to slow your needle down, as far as your clocks are concerned they are still reading in kph and being driven really slowly, so the therefore the odometer is turning at a slower rate than normal to show miles covered rather than kilometers.
bigal
Post by bigal »
car imported 2004 with 73,030 kms=45,360 miles
clocks converted before I bought car off 1st uk owner at about 75,000 miles
showing on clock.
Car has now done 91,253 miles.
Actual miles done=63,583 total. :D
Return to “Electrical”
