all OEM from toyota, or are there suitable blueprint parts etc?
ChrisW wrote:Best to stick with Toyota for those parts- more expensive but you know they'll be good for 10+ years.
jimGTS wrote:expect the best part of£200+ for those,
dizzy and rota is about£80-90, leads, around
£130
the coil, who knows, but given the above prices, likely alot!
samgpr50 wrote:Just done all of mine got a coil from euro car parts for£30, Dizzy cap from the same place for
£25 then got a genuine rotor
(free) And a set of NGK leads from GTS Chris for
£70.
samgpr50 wrote:They seem ok, use the standard clip connection and have a limited lifetime warranty.They are a little shorter and you will have to loose the plastic tidy.
Can get a photo if you want.
I also had the same thing with the coil.Went in the worst place possible!
jimGTS wrote:ive only got blueprint dizzy and rotor once, but they seemed perfectly fine to me, couldnt tell the different to the oem ones which are X 3 the price.
leads i would always get from toyota.
however im sure rev2 tubby leads maybe cheaper than rev3, so you could use those as same size(just dont come with cover, but you can obviously reuse your cover)
coil, im sure a good secondhand unit would be fine.
