A few facts that may or may not help diagnose.
Ideas????
I need the car running yesterday as it's my daily drive
thomp1983 wrote:The stock voltage indicator is next to useless, if your battery has been low the ctek won't have had chance to do much overnight.You need to get it started then measure the voltage across the battery terminals, then go from there.
Trying to do a drain test with a flat battery can also be misleading
Chris
stephenj wrote:Could it not just be a bad battery?
synXero wrote:Curveball- starter motor issues?
stephenj wrote:If it was an earthing issue wouldn't you have the same problem no matter what battery you were using.
Get the new battery on charge whilst your tinkering and then see if it discharges, it cant hurt to check.
synXero wrote:Oh, I didn't click that.
If your battery is losing charge overnight it has to be a parasitic drain, no? It's unusual(and I hope wrong, since I've just bought one) but could your CTEK potentially be to blame.
tottacrolla wrote:Probably draining power through the alternator.
