What de-cat pipes are people using? I've currently got a cheap steel eBay de-cat pipe that I've had on the car for a few months and it's already rusting. I've just purchased a shiny new 5zigen exhaust, so I don't want to be using the current eBay one as it'll look a bit rubbish mated to something shiny.
I know there's a few options;
Mongoose at £100+
Japspeed at £79
And a few other eBay ones look VERY similar that cost slightly less.
So I'm guess my question is what are people using currently? I know they all do the same job, but I don't want to be spending so much on a de-cat pipe if it's going to fall apart or rust instantly
[Mk2] [NA] De-Cat Pipes?
Re: [Mk2] [NA] De-Cat Pipes?
I have a Nür Spec from a turbo '2, ditched the flexi section in to the pit that is my shed and cut the right angle-ish tube till it was the right length then welded a flange on so when it comes to MOT time I can just unbolt the pipe and bolt the cat back in. Bonus is the exhaust system is all stainless
I went to my local stainless exhaust place and had a stainless de cat made from scratch. £120 supplied and fit..
C & C exhausts hillington just outside glasgow.
Well chuffed
Well chuffed
