I have Supra wheels on mine.
10mm spacer on front,not needed on the back,with the following tyres -
Front 205/50/ZR16
Rear 245/45/ZR16 (all Dunlop SP Sports as the Prixes at front and Michelins on rear were dreadful)
Repainted in steel grey
Very happy with them (and so easy to keep clean!)
Thanks for that. I have put yokohama 225/45 R16 on these wheels for trackdays.They should fit if yours do. I have found these longer studs . http://www.ebay.co.uk/itm/271208491331? ... 1423.l2649 What wheel nuts do you use?
I got a full set of nuts with the Supra wheels when I bought them,so don't know for sure if they're standard Supra nuts or nit.
225's won't fit front as that's shat was on my wheels.
I went to the 205's and they still just touched suspension,10mm spacer cleared it and had no problems since.
