I had some rev2 leads, dizzy, rotor arm, cap and ignite/coil knocking about so fitted all these to the rev1 but found the big loom plug wouldn't fit the ignite from the rev2, so I swapped the igniter from the rev1 onto the rev2 coil so everything fitted and put it all back together.
I now have no spark from the coil.
Has anyone had any experience swapping these bits around, and is there a good solid reason why it definitely wouldn't work?
i'm thinking that either the rev1 igniter doesn't like the rev2 coil for some reason, or I have a bad connection or something.
Any help much appreciated.
