Tyre Loading MR2 Turbo
vanman1936
Post by vanman1936 »
Hi
I have 17 inch wheels with 215/45 rear and 205/40 front - what are the minimum tyre loadings and do these change if I move up a tyre size or are they weight loading consistent across tyre sizes?
Paul
Odin_S
Re: Tyre Loading MR2 Turbo
Post by Odin_S »
Your tyre setup is all wrong, get the correct width on the rear before worrying about load
HighwayStar
Post by HighwayStar »
Agreed.
You want a 225 minimum or 235 (I find a 20 mm f/r stagger the most neutral but if you don't like oversteer go for the 30mm difference) on the rear... probably in a 40 profile to match fronts but I've not done the calculation for rolling radius myself on 17s (but no reason for a larger profile on the rear I can think of). Worry about correct fitment, speed rating and getting a quality rubber on before concerning yourself with loading. Loads of threads about the 'best' 17" tyres but it's all personal preference. Just pick a decent quality brand and have them fitted by people who can properly balance a wheel and tyre. :thumleft:
R.
PS. You haven't said but what width and offset are your wheels front and rear?
