hi
, that is repairable and I've repaired a lot worse
, it will have to be cut out
and has all ready said use a doner floor pan but where the rot is climbing up the side of
foot well cut out and look inside to see how bad the inner chassis is
i noticed yours is a sunroof and shouldn't be
usually suffering corrosion there so you have a major leak you will have to find
it could be a few place around the front drives corner
1 check the scuttle panel
under the screen where the wiper arms
run
(rotten
usually right in the corners and its the
dash out to fix it
remove wing and check A post at the top where water runs out from scuttle panel above
( you will usually see rust stains near the little fuse box
) but saying that you get the same rust stain marks
from the wheel
arch rotting out behind the plastic liner
my main concern would be front chassis section now
,if that's ok
fix and enjoy
