AFAIK none of the early solid colours were lacquered.
they only started clear coating them when they went to water based paint.
easy way to tell is rub it with a little compound if the cloth turns body coloured then you dont have clear coat.
EDIT: might be hard on yours though as clearcoat goes white on the cloth as would yours if it wasnt
