My Rev2 turbo engine was rebuilt 5000 miles ago and is a standard rebuild with the usual breathing mods and the boost is upto 1.1bar.
Not had a problem really up until I went to Silverstone to do a track day.
alan wheeldon wrote:Ok from what I can gather it is running lean due to a mixture of too much boost, too high an air/fuel mixture or the timing is too advanced.These are the symptoms of knock so I either need to
Reduce the boost pressure
Buy an adjustable fuel pressure regulator and lower the ratio
Does this sound about right??
