Hi guys, hoping some of you knowledgeable folks might be able to help with a diagnosis.
I've fitted the mechanical parts from my 86 mk1 into a custom made buggy frame,
http://www.imoc.co.uk/forums/viewtopic.php?t=168209), but now that completing the final assembly I went to fire the engine today and i'm having some problems getting a spark.
I'm thinking that if I describe the problem somebody out there who knows the system better than me might be able to point me in the right direction.
I have had the engine running while mounted in the spaceframe but took it out for final welding and paint and this is the first time I've tried to fire it since.
I have tweaked the wiring a little,
(moved the battery to the front and removed the key/barrel and replaced with a series of toggles and a push-button start), but i'm fairly happy that that I've reconnected everything where it should be and haven't done anything very stupid.
The engine is spinning nicely and I have fuel being delivered but I have only got a very occasional spark.
The problem seems to be across all cylinders, no cylinder is sparking correctly but I have seen sparks on at least 2 of the 4.
The spark looks reasonably strong when it does appear but just not frequent enough.
I removed the dizzy cap and all looks fine, so I just cleaned it up a little and re-installed, all the HT leads are in the right places and the 12v plugs are connected and appear ok.
I'm wondering about a coil/igniter problem but I don't know the system well enough to know what other possible causes that I maybe should be considering.
Any suggestions welcome.
Russ
