wide spacers
wide spacers
after some wide spacers for my mr2 mk1 as got a wide arch kit need 25 or 30mm what do people recomend?
Re: wide spacers
Honestly I'd suggest wider wheels or wheels with lower offsets.
Re: wide spacers
got wider wheels just need a touch wider
Re: wide spacers
sherwin1983 wrote:got wider wheels just need a touch wider
Get some hubcentric spacers perhaps
You may need to fit extended wheel studs if the spacers are more than a a very few mm in thickness though
Wheelnuts need to go 8 turns minimum onto the studs to be safe
I agree though, wider wheels or less offset would be better than messing with spacers
Sell the wheels you have & get some different ones perhaps
Re: wide spacers
You should be OK with 25mm spacers and longer wheel studs - try Vauxhall ones (I think). This is the maximum allowed by the MSA for racing / rallying etc.
What wide arch kit have you got? Any pictures?
Re: wide spacers
As the hubs at any Toyota have a really short centralization You´ll need longer studs for 5 to 15 mm spacers per side. From 20 mm per side You can use the DRM spacers from H&R wich have own build in studs to bolt the wheels on:
