Hello,
The plan for next year is to megasquirt my Rev 2 and run a
(Lag assist only
) direct port, wet Nitrous kit.
My question is, before I go ahead investing time in machining the rev 2 plenum for the Nitrous and boring out the fuel rail making it twin feed etc.
Is there any fundamental advantage in using a Rev 3 head instead
(I want to find out now as manifold/fuel rail is not interchangeable)?
When my stock Rev 2
(but only 17k miles of use)
head gasket eventually goes
(I predict at some point next summer)
I'll consider doing some headwork when the car comes off the road.
aswell as swapping the rebuilt CT26 to a CT20B
So by fundamental advantage I mean one that a rev 2 head could not achieve with retrofitted Rev 3 parts.
I heard the Rev 3 cams are
'better',
can anyone tell me what is different about the profile?
And can they be retrofitted to a Rev 2 head?
I know Rev 3 loses T-VIS and this may help peak power figures, but as the car is used for Sprinting I am quite keen to keep TVIS to attempt to maintain low RPM drive-ability
(being able to stay in gear can save time).
In Summary:
If I bore out the Rev 2 fuel rail and use rev 3 injectors,
would prefer to keep TVIS
(may go for a larger plenum in the future like the ATS manifold),
will be using the Megasquirt map sensor and rev 3 headgasket anyway and will have all winter to port inlets etc.
of my rev 2 head and convert to Rev 3 Shim-Under-Bucket or 1ZZ shimless buckets
Is there any advantage at all that a rev 3 head would
have over this
other than the cam profiles IF the cams are not interchangeable?
Sorry for the long winded question,
another consideration is that I already have the rev 2 head and all mating parts AND have a spare rev 2 head/engine,
so if there is no significant real world advantage,
then it won't be worth me considering.
Thanks in advance
Dan
