Despite the Mini being faster and handle better than the MR2 NA, I am missing the whole
Here's the car, already spent over
It's not a lemon, the problem is me
Here's where some of the money has gone.
Found some spoon had changed a single spark plug
Brakes had plenty of life in them, but weren't up to the standard I'd become used to with the Carbotechs on the MR2, so had to be replaced
BMW/Mini say the fuel filter NEVER needs replacing, so I change that
BMW/Mini also say the gearbox oil never needs replacing
Crazy oil change intervals, something like 20,000 miles.
Car has reasonable service history, but some garage skimped here so I've been breathing in some new diseases
Discover the car has a mushroomed strut tower
Car drives perfectly though, so it probably wasn't essential that I did this
Thanks to the incompetent designers at Rover, shock absorber is attached to the hub via a single bolt
](./images/smilies/eusa_wall.gif)
Bought some plates that fit above and below strut towers to help prevent future mushrooming, and use them to also fix it
Latest pic with an Aero grille
So life after the MR2 NA,
The good:
The Mini is faster, better handling, a lot more modern
The bad:
The Mini is very poorly designed in many areas and has many common problems.
I think I need a Japanese sports car
