Fao Mark Edwards - st205 c/c install
mikewright
Post by mikewright »
Hi Mark i spoke to you before about the st205 c/c install and you posted a picture of yours so i could see how it all plumbed together. Could you post this again as i am trying to see how to fit the hks ssqv on there, i assume it comes of the pipe on the back left of the c/c but what adaptor did you use for this? Cheers for the help mate.
Mike
Mark Edwards
Re: Fao Mark Edwards - st205 c/c install
Post by Mark Edwards »
Yeah it does come out of that pipe. It's just a case of fabricating something to fit. I hunted round a local scrappy and found that a rover 214 rad pipe is the right bore so cut the 90 degree bend out of it and used that. How's yours going then, getting there?
xxxx, AM TUNING, sbITs
chrisbilling
ST205 CHARGE COOLER PICS
Post by chrisbilling »
raptor95GTS
Post by raptor95GTS »
for the lazy amongst us
mikewright
cheers Mark yeah it's getting there very slowly. Engine is very nearly built now so just got to have it reunited with the car and the chargecooler plumbed in. Then it's a case of running in before the injectors and ecu get fitted. Can't wait to see how this is going to perform when i have it finished. :D
