Thanks for any help, Tam[/img]
Ninjat wrote:Its like this; the lower spring cup is locked to the strut by locking collars, the spring is then held at the top by another spring cup, which sits against a metal spacer, which then sits against the top mount which is bolted to the car.
[/url]
Ninjat wrote:Ive spoken to driftworks and they are really good, but they are advising me this is a normal symptom of new coilovers, and they will bed in over time, I hope they are right, but it feels like its binding way to hard, I cant post pics here as I havent posted enough.What type of bearing would there be, on my Dualtechs the top spring cup is definately just rubbing against a metal spacer, I was hoping someone would have a pic of their own for me to compare.
Im driving to Eindhoven on Friday so hope they are sorted by the time I get back,
~600miles.
Will update as to what my outcome is.
Thanks for replies, Tam
bobhatton wrote:
I have never had to bed in any coil overs, but then again I have never had cheap Chineas makes.
I would take them off and make sure you can get them to turn on the work bench, you have a problem with them
Ninjat wrote:Hi, thanks for putting my pic up rev3turbo, just had a reply from driftworks and apprently the design has changed, they say"Recently the spec on the coilovers have changed from the pic you have attached.
They used to have pillowball top mounts and roller bearing spring seats, but to make them more comfortable, they were revised to be rubber top mounted.
I have again been told that they should bed in over time so will give them some time.
Gonna ping my way over to Eindhoven and see how I get on.
