Also, what would be deemed as low pressure
Oil in my car Is 10w 40 semi, castrol gtx magnatec.
Magic Beans wrote:Out of interest what's thenormal
oil temps when warm?
greeny wrote:Personally I'd be getting a little concerned with only 8psi at idle when warm, especially on a refreshed engine.![]()
The stock low pressure switch, switches at 7psi iirc.![]()
Have you noticed the pressure getting lower over time?
calum4492 wrote:gaz get rid of the cheapy gauge mate i had 1 from ebay and it red about the same as ur saying so i got abit worried and phoned nathan from century, so with a bit of advide from him i swapped my old gauge out for a new greddy 1 and the pressure sits exactly where it should now
ashman wrote:How have you got your oil system set up Phil? Remote filter, oil cooler, grade of oil??
