Hi
Has anyone had problems with fitting HSD coilovers?
I have just brought some and the bottom brackets on th rear coilovers seem not to fit?
Dan
HSD Coilovers not fitting?
Re: HSD Coilovers not fitting?
Mine were tight on the back due to a surface rust buildup where the two bolts go, just cleaned the whole area up and they fitted,
These are about 2mm out i even filed the back if the hub flat and its still way out.
I will speak to driftworks in the morning and hopefully they will send me just replacement rears that it.
Hey buddy, must be in the same boat! i bought my HSD coilovers a few days ago and just fitted the last one but didn't get round to finishing it off as it got dark! Fitment in both the rear brackets is very tight, we spent over 2 hours trying to wriggle and get the fitment to work. In the end we got it to fit, we placed both the 19mm bolts in at the same time and slightly tapped the bracket with a hammer and it eventually lined up. Good luck
The worrying thing is they are not even close.
TRINDA1664 wrote:These are about 2mm out i even filed the back if the hub flat and its still way out.
what they say?
Ive sent an email with these photos and they havent replied yet.
Fitment is extremely tight in the rear. I've had the same issue. I used an air gun to spin the bolt into the hole. It got there eventually. Not something i want to have to do again in a hurry.
Which coilovers did you go for? MonoPro or the DualTech?
Ive gone for the dualtech coilovers, i will give it another go tonight but i may machine the holes out by 1 or 2mm just to help me out.
TRINDA1664 wrote:Ive gone for the dualtech coilovers, i will give it another go tonight but i may machine the holes out by 1 or 2mm just to help me out.
It could be worth a shot, or just get a rounded file in there.
I'd try to avoid enlarging the holes - may mess with the camber? Not sure, but just in case
TRINDA1664 wrote:Hi
Dan
HSD say
Our Total Satisfaction Guarantee
Were so confident youll be impressed with the quality and performance of our coilovers that we offer a 30 day, no-quibble money back guarantee. How many other companies would offer you that?
So send them back
Blimey, I saw this topic title and thought it was mine! About 3 or 4 years ago I was in a GB for some of these. And I had the exact same problem. After much discussion with Driftworks (who the GB was organised through) they eventually got some new, amended brackets for me. Took months to get resolved, but yes, there is an issue with possibly only Rev1's (which mine is).
SW20 Rev1 Supercharged 2GR-FE Powered Trackday Car.
If i drill the holes out by 2mm will it effect the camber much?
There's no need, you can get some proper brackets like I did. Get in touch with them. I wouldn't be drilling anything out.
What do you mean proper brackets? How are they different to what they send you orginally?
The brackets that are welded onto the strut collars. They are different. The swapped over the entire bracket for me once I gave them the correct dimensions.
Thanks for everybodys advise and suggestions. I tried again last night to fit them with no luck so i have decided to send them back and get a refund.
Many Thanks
Dan
Many Thanks
Dan
TRINDA1664 wrote:I tried again last night to fit them with no luck so i have decided to send them back and get a refund.
The only correct decision unfortunately.
I have done a deal and I am going to try some MonoPro coilovers.
As these are more expensive, fingers crossed they fit.
