SC map sensor
Elliott_Knight
SC map sensor
Post by Elliott_Knight »
90% of the way through the engine conversion and I have come across a set back. The map sensor I have is broken :(
Does anyone have one? Know where I can get one?
A imoc member said that mk2 turbos could have a compatible sensor. Does someone know this for certain?
The sooner I get one the sooner I can be supercharged! :twisted:
"I'm so gangsta I eat the cereal without the milk"
jimi
Re: SC map sensor
Post by jimi »
The MK1 SC doesn't have a MAP sensor, it uses an AFM. The later Corolla (AE101) small port AGZE engines used a MAP sensor but I have no idea if the MK2 turbo sensor is compatible. If you post the part number of the broken MAP sensor I can find out if it's used on anything else
User avatar
Lauren
Re: SC map sensor
Post by Lauren »
His engine uses a MAF as it's AE92 late spec.
Elliott_Knight
Re: SC map sensor
Thank you Lauren I should have specified. I'll get the part number listed later, thank you
