Just doing a bit of research really.
Any advice or experience with a similar thing or your own Coilover spring rate would be fantastic
Nic wrote:Have you lowered the ride height? Anything more than around a 25mm drop and there is very little suspension travel left which can cause the suspension to bottom out over rough surfaces.Before swapping the springs I'd try raising the ride height a little to see if it improves the ride.
glimitedmr2 wrote:Hi all,
Just doing a bit of research really.I've just bought some HSD MonoPro coilovers for myself.
Fitted them fine and have had them on for the past 1-2 weeks.
Absolutely over the moon with them.
Handling is superb, build quality again is superb but I can't help but think that the spring rates I've got are a tad too stiff for my use.
Spring rates I've got as default are 6K front and 10K rear.
Now I do A LOT of fast road driving and plan to drive to Italy this year
(cobbled roads) and hopefully attend a few track days towards the end of the year.
So I'm thinking of maybe changing the springs down to 4K front and 8K rear.
Hopefully that might be my ideal set up.
Any advice or experience with a similar thing or your own Coilover spring rate would be fantastic![]()
glimitedmr2 wrote:or that uprating the ARB bushes could of had an effect on the comfort?
Peter Gidden - SBITS wrote:
Impossible.
What are the spring rates?
glimitedmr2 wrote:Peter Gidden - SBITS wrote:
Impossible.
Hi Peter, I didn't think so.But i was just doubting myself.
Spring rates are 6 front, 10 rear.
But after speaking to a few people, same coilovers and same spring rates, they've praised how comfy they are!
Herts66 wrote:Have you checked you did it right and haven't preloaded the spring?
glimitedmr2 wrote:I've followed the instructions properly, set the pre-load so it just cups the spring
Herts66 wrote:Sounds like a preload issue.![]()
Loads of videos on utube on this.
Classic mistake is often to use the spring to set the height instead of the height adjuster.
