[Mk2] [Turbo] ct 20b turbo
tazracing
Post by tazracing »
just bought a ct20b turbo and on inspection found a crack in one of the wastegate tubes,exhaust housing no 74040.can this be fixed by welding or a metal chemical sealer or is it shot,the rest of the turbo is in good condition
thanks chris
sp00n
Re: [Mk2] [Turbo] ct 20b turbo
Post by sp00n »
Hi mate,
i dont think anyone will give you a diffenitave answere either way, there are too many variables (skill of the preson welding, composite of the original metal etc etc)
that said a pic might help :thumleft: , as it may just be a hairline surface crack, which sould (*may*) not cause you any issues.
your best bet is to get a turbo expert look at it though :thumleft:
post a pic though :thumleft:
Peter Gidden
Post by Peter Gidden »
I'd return it to seller.
