Mk1 B ARB
Charged
Mk1 B ARB
Post by Charged »
Can anyone tell me the diameter of a standard Mk1b rear ARB?
Finn
Re: Mk1 B ARB
Post by Finn »
My -89 has 19 mm front and 13 mm rear. FWIW, on track they feel a bit too small in diameter.
un1eash
Re: Mk1 B ARB
Post by un1eash »
I thought rear ARB's came in 10,12 and 14mm. If you say its 13mm i would guess its actually 12mm but just rusty. Fronts are all 18mm i believe.
Finn
Re: Mk1 B ARB
Post by Finn »
Very possible - I measured both with vernier caliper after trying to get rid of the stuff on the surface. Could well be 18 and 12 on mine.
User avatar
Lauren
Re: Mk1 B ARB
Post by Lauren »
12mm for MK1b.
Charged
Re: Mk1 B ARB
Post by Charged »
Thanks folks!
Finn
Re: Mk1 B ARB
Post by Finn »
While on the subject:
do you know who might stock Whiteline ARBs for Mk1 in UK?
Charged
Re: Mk1 B ARB
Post by Charged »
Finn wrote:While on the subject:
Fensport
Finn
Re: Mk1 B ARB
Post by Finn »
Thanks for the tip. They appear to be out of stock, I'm afraid. :(
Charged
Re: Mk1 B ARB
Post by Charged »
Finn wrote:Thanks for the tip. They appear to be out of stock, I'm afraid. :(
You may find Fensport are their UK's exclusive dealer. I could be wrong.
A Mk2 Mr2 rear ARB is a good cheap upgrade.
PW@Woodsport
Re: Mk1 B ARB
Post by PW@Woodsport »
Indeed, i find the Mk2 ARB a better upgrade than whitelines.
pk_090
Re: Mk1 B ARB
Post by pk_090 »
Mk2 turbo? any specific revision?
Alex
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming 'stop raping me' :D
PW@Woodsport
Re: Mk1 B ARB
Rev1 or 2 bars work very well, use Mk1 front brackets with them :thumleft:
aw11rally
Re: Mk1 B ARB
Post by aw11rally »
I agree.
If you havn't got any mk1 front mounts its not too challenging to knock some up yourself, I used 2mm stainless plate.
A very cheap and effective upgrade, cost me £0 in total.
stenky
Re: Mk1 B ARB
Post by stenky »
try camskill, better prices there too :)
http://www.camskill.co.uk/m5b0s2378p0/T ... ion_-_Misc
Finn
Re: Mk1 B ARB
Post by Finn »
Thanks Stenky. :salut:
stenky
Re: Mk1 B ARB
Post by stenky »
if they would ship those big things to Finlandia for promised 20GBP, i'll take the whole set right away :)
Finn
Re: Mk1 B ARB
Post by Finn »
Their actual freight cost on tires was exactly what they advertised - I got my Hankooks from them. Need some financial arrangements first, though. :oops:
Would be good to know whether they would actually be an improvement over the originals.
stenky
Re: Mk1 B ARB
Post by stenky »
well 20/18mm over 19(18)/12(13)mm should make a considerable difference. probably not so much for the front as it will do for the rear.
i am not sure about the size of the mk2 ARBs and whether the mk2 front is interchangeable as well as the rear is.
LimeyMk1
Re: Mk1 B ARB
Post by LimeyMk1 »
I have a 19mm rear ARB on my Mk1 and it's chuffin brilliant.
I'd keep the front ARB stock, it's plenty thick enough I reckon.
