So my head is getting kinda fried.
My 2' is pretty much standard apart from an HKS mushroom filtery thing
(don't like the look of it design wise, can't see it filtering particularly well?) and what seems to be an aftermarket IC of some kind, poss HKS as discussed in my
"Is my intercooler custom?" thread.
I just don't know where to go mod wise from here, been reading so much stuff I've just flummoxed myself I think.
Just as I had a pretty fine idea what to do, I started reading that the stock ECU needs replaced pretty much straight off??
My plan was only to get the exhaust sorted out
(still factory), get a decat pipe
(I have a feeling mine might have been gutted already, will check when doing exhaust), modest boost increase
(14psi) and for reliability, although prob not needed but because I could make a project of it myself, maybe playing with WI
- I need little things like that lol
Would the stock ECU do all that OK?
If I have to go custom ECU I just have no idea where to start; I am not sure I can justify the budget for it either, in terms of the unit itself, or the setup time it might
- will
- require.
So, how far can the stock ECU go?
Who has good road power on a standard
unit?
What are your specs?
Help me de-confuse myself
- I'm not interested in monster power, just a good increase, and with as much reliability as is easy and cheap to get lol
On a side note, I just don't feel that impressed with the grunt of my 2' any more.
well have never been blown away really
- maybe I am expecting too much.
I mean with the custom IC and filter surely it should be making a tiny bit more than stock.
boost seems slow to come up
- but admittedly I have nothing to compare too.
I also still need to check that various systems are working right, TVIS, TVSV etc, but the engine does otherwise seem in great condition.
Might be worth a code read to see if that throws anything up.
But yeah, stock ECU, what have you guys got from it and how?
