[Mk2] [Turbo] Best EBC
b4nk51e
Post by b4nk51e »
Hi guys/gals what's the best electronic boost controller to use with the MR2, i've been looking at the Greddy profec B & Apexi AVCR or are there others I should consider i've seen the Gizzmo ones but they seem cheap compared to some of the others. What you using?
John
Peter Gidden
Re: [Mk2] [Turbo] Best EBC
Post by Peter Gidden »
Blitz DSBC Spec R. NEVER had a problem with them, and easy to set up.
Nic
Post by Nic »
Best, as in number of features and function it would be the Blitz SBC i-Color or HKS EVC, both are able to map multiple boost settings against rpm, speed, throttle position, etc. which helps to maximise boost and turbo response at all speeds and in all gears. However to get the best out of them takes a LOT of time setting up.
I've used both and preferred the HKS EVC because it had the clearer screen and was able to be linked with the HKS F-Con ECU which I was using at the time.
HKS have just launched a new version of the EVC http://www.hks-power.co.jp/en/products/ ... /6evc.html
Nic
[email protected]
MR2 Rev 3 GT Turbo
Turbonoz
Post by Turbonoz »
I'm running a ProfecB Spec2, it does the job very well.
92 MR2 Turbo Rev2 stock engine, Link G3 TURBONOZ mapped, T78: 487bhp & 364lbft; 11.78@120. NOW BREAKING: www.imoc.co.uk/forums/viewtopic.php?p=1542658
94 GTiR: 12.08@115 TOTB Sold :(
92 300ZX: 12.6@113 (415bhp) 570bhp, 500lbft
00 Clio 172
05 WRX PPP
2barGee
Post by 2barGee »
Profec b spec 2 is my fav.
RyanRs
Post by RyanRs »
Profec b spec 2 on mine, happy with it :)
les85
Post by les85 »
Profec B spec2 for me aswell, simple to set up and does the job well. I did have an AVCR but i got rid as it was a PITA to set up properly.
2barGee
Post by 2barGee »
les85 wrote:Profec B spec2 for me aswell, simple to set up and does the job well. I did have an AVCR but i got rid as it was a PITA to set up properly.
And no over boost control which some others come with
