Does anybody know what wiring has to be changed to get this working? Have done a search and Rogue mentioned that there is a wiring change but didn't say which wire it was.
](./images/smilies/eusa_wall.gif)
BTWW wrote:A little worried about the knock sensor though as I thought they were the same between Rev's 2 and 3.
Had no error codes before the swap.
BTWW wrote:Where's best to check for continuity between? Pin 13 and the knock sensor? Or pin 13 and ground?
