[Mk2] [Generic] SW20 FRONT BRAKE CARRIER PCD
Hi,any one know front caliper bolt hole pcd
?thx
Hi,I might not explained what
is needed the front caliper
has 2 bolt holes to attach it to hub its that pcd I require thx
Re: SW20 FRONT BRAKE CARRIER PCD
mitec31 wrote:Hi,I might not explained whatis needed the front caliper
That was what you had said in your first post, easy to understand, but its not 114.5 that is the wheel studs
Re: [Mk2] [Generic] SW20 FRONT BRAKE CARRIER PCD
Just measured a spare front brake carrier I have here, mounting holes centre to centre looks to be 149mm
- measured with a tape measure so that's as accurate as I can get.
