As it happens after taking my entire dash out the first time round to get to a good condition matrix, I realised the the matrix simply slots into the back of the heater housing with just a couple of retaining screws that hold it in.
Firstly i disconnected the hoses and then marked out where i would need to cut the hole in the front bulkhead.
Then armed with a 4" grinder i set about cutting out the hole.
I wouldn't say its the neatest hole tbh and i probably cut it slightly bigger than i needed to, but really i followed the contours of the bulkhead.
And just as i thought undo the two retaining screws, one holding the matrix into the housing and the other around the left pipe and it pulls out.
In all honesty you could do it in 20mins if you are good.
Refilled the system ran it up to temp and hot air!
all i need to do now is make up an ally plate to go over the hole.
Pics:
as you can see i cut the hole a bit bigger but you can see how far the matrix is behind the bulkhead.
Here you can see the matrix coming out.
The heater matrix housing.
New
