I've rebuilt all my brakes and fitted braided lines but I haven't put ant bbrake fluid in yet, I figured I'd test the rears via the hand brake first so I don't have to drain all the ffluid again should they not work.
so in simple will the handbrake still work if there is 0 fluid in the system as its independent being cable or shall I wind the piston out a lil more.
Liam
