Oil Leak
ToyotaTosh
Oil Leak
Post by ToyotaTosh »
Would someone be able to help me figure this out. Its coming from above the undertray, in front of the oil filter.
Peter Gidden
Re: Oil Leak
Post by Peter Gidden »
Possible candidates are lower sump to upper sump, upper sump to block, turbo drain hose at bottom of drain pipe.
See how high up the front of the block and the sump the oil deposits are.
ToyotaTosh
Re: Oil Leak
I'm going to get under it now and have a look. Would it have anything to do with the recent clutch change?
ToyotaTosh
Re: Oil Leak
Scratch that, its raining :(
Although I have just checked the oil level and there is too much in there, so I guess it'll be spurting out everywhere...
ToyotaTosh
Re: Oil Leak
Looks like its coming from the turbo area. I've checked the oil level again, and it has seemed to level out, so maybe its only the excess that has escaped as no more leaks have appeared on the floor....
Fingers crossed its ok :thumleft:
ToyotaTosh
Re: Oil Leak
If you can zoom in you can see where it is coming from, but I dont know the part name which doesnt help :(
Peter Gidden
Re: Oil Leak
That looks like the underside of the inlet manifold. In which case, 3 well-known possibilities:
1) Rear of cam cover gasket
2) Distributor shaft O ring
3) Bottom of catch can oil drain hose (Rev3+)
ToyotaTosh
Re: Oil Leak
From what I can see, there is a slight crack on the inlet manifold.
On the possibilities you have listed, are they difficult to tackle?
I'll also PM you about the plug I asked about, I just havent got 2 mins to myself at the minute.
Peter Gidden
Re: Oil Leak
ToyotaTosh wrote:From what I can see, there is a slight crack on the inlet manifold.
Very, very unlikely. Have never seen a cracked inlet manifold.
ToyotaTosh wrote:On the possibilities you have listed, are they difficult to tackle?
1) Not too tricky if you have a basic tool set.
2) Can be tricky aligning distributor drive dog with camshaft, but easy if done at same time as (1)
3) Easy to check - if a bit of a pain to get at.
djminor
Premium Member
Re: Oil Leak
Post by djminor »
As Peter mentioned, the rocker cover is a common source of leaks.
Due to the angle of the engine, the oil has a tendency to run towards the rear and onto the inlet manifold, before spreading to any number of strange places (partly due to the aerodynamics).
Does the sill around the back of the rocker cover have oil around it?
As can seep slowly so you may barely notice it on the dipstick but, after time, it makes a nice mess of your car and driveway!
The manifolds are fairly robust, although exhaust wrap has been known to cause issues on occasion
