Just wanted to know how much roughly a bottom end rebuild will set me back?
To a standard 3sge.
Have you guys had any experience in this?
Any help would be much appreciated.
Peter Gidden - SBITS wrote:£995 New Internals
- Way over the top
£250 Labour
- Too cheap for removal, strip down, rebuild and refit
£85 Gaskets, Liquids
- Too cheap for quality parts
Zogbee wrote:I've found a REV 2 engine for£350 UK spec.
Would I still be tested as an import during MOT with my decat?
Zogbee wrote:I were to get the REV 3+ 3sge, would it fit straight in? I've heard talk about replacing the ecu too?
BrianUK wrote:Never heard of a garage that would recomend taking an engine out just to change shell bearings- not even Toyota.
But the nice thing about technical discussion is that we are all entitled to our opiinion
The last car I changed the bearings on has done at least 25,000 miles.
If the shell bearings are worn, there should not be any shards.If they are damaged then yes there may well be.
in that case however its likely that the crank is scored
- and it that would be an engine out job.
Andhopefully
any metal shards that do come off the bearings will
1) Fall to the bottom of the sum pan, or
2) Get stopped by the oil strainer, or
3) Get stopped by the oil filter.
Brian
