[Mk2] [NA] Clutch problem please help!!
richard1984
Post by richard1984 »
Please help!!!
My car has a weird clutch problem???
I can press the clutch to the floor but clutch will not disengage fully I can turn off the car start it again and then it works fine I left the clutch pedal jammed down well over 24 hours to see if it will self-bleed in case there was air in the lines it did work for 2 whole days then back to square one
Could this fault be a slave / master cylinder?
When the clutch is working u can heard a small squeak from the clutch area when it’s not working silence????
Peter Gidden
Re: [Mk2] [NA] Clutch problem please help!!
Post by Peter Gidden »
richard1984 wrote:I left the clutch pedal jammed down well over 24 hours to see if it will self-bleed
Will never happen.
richard1984 wrote:Could this fault be a slave / master cylinder?
Most likely. If you hook the pedal up with your foot, and then press the pedal, does it feel normal on the downward stroke?
If so, master or slave cylinder.
richard1984
the pedal feels normal like its got pressure know what i mean and cart lift up with foot as it rurns to the top???
Peter Gidden
Slave or master cylinder seal gone.
Might as well change both whilst at it. About £20 per kit.
richard1984
thanks mate apriciated
