Would it be a good idea to spend a bit more
LeSpank wrote:I haven't driven a mk1 with Konis but if it's any help I am really impressed with the BCs that I fitted recently.They are really smooth and comfy with the right damping setting and springs.
LeSpank wrote:4 and 6kg/mm![]()
How are you finding them? Think I saw a pic of your car wearing them!?
Limeymk1 wrote:LeSpank wrote:4 and 6kg/mm![]()
Ended up with 5 front 8 rear but may buy some lower rates if they end up being uber hard.![]()
Car's still not MoT'd so not had the chance of a full test, but they feel ok so far.
Gad wrote:Don't suppose they do BCs for a MK1a do they?
Limeymk1 wrote:Peter any half decent coilover kit should come with a choice of spring rates.
elbon50 wrote:Limeymk1 wrote:Peter any half decent coilover kit should come with a choice of spring rates.
Do they all come with adjustable damping Chris![]()
PW@Woodsport wrote:Yep on a Mk1b you can fit Mk2 coilovers by just changing the topmount for a Mk1 type, on my V6 Mk1 i've gone with Mk2 KW coilovers and Technotoy adjustable camber top mounts.
We've been fitting Mk2 coilovers to Mk1's for years without issue, for info Mk3 stuff also fits a Mk1b, again changing the topmount.
On a Mk1a they will fit on the front, but you need to modify the rears.
