Right put my rev3 tubby in for mot it failed on Emissions but they will get it through , lower front ball joint , rear wheel bearing , excessive travel on handbrake ...quoted all in parts, labour and vat £260 ...seems a bit expensive ? ...appreciate your opinions ...cheers
StevenstonWullie wrote:Right put my rev3 tubby in for mot it failed on Emissions but they will get it through , lower front ball joint , rear wheel bearing , excessive travel on handbrake ...quoted all in parts, labour and vat £260 ...seems a bit expensive ? ...appreciate your opinions ...cheers
Front ball joint: £20 plus 30 minutes.= £40.00
Rear wheel bearing: £60 plus 2 hours.= £140.00
Adjust handbrake: 30 minutes max.= £20.00 £200.00 all in.
Bent MOT on emissions = priceless
Mine failed on emissions but they let it through. I've since had a thorough service changed everything to try to get it below the emissions. Hoping next year my car will pass..
fit the parts other than the wheel bearing yourself to save on hours in the garage, always fit parts yourself where possible, if you don't have the tool to do the job then that is the only time you should pay a garage to do it
[quote="dantheman"][quote="JSandW2"]if you don't have the tool to do the job then that is the only time you should pay a garage to do it [/quote]
I find the cost of labour often covers the cost of the tool anyway, then you will be equipped for next time[/quote]
well said
