Hi all.
The problem is on my track/
touge car.
SW 20 GTS rev3.
It has an ORC clutch and celica alltrac 2nd to 4th gears.
After about 1500miles of driving the clutch began to drag after driving.
It would be fine cold.
But little driving and drag.
Making it hard or impossible to downshift without blipping the throttle.
Then I bled the thing.
No change.
Then I adjusted the pedal.
Did 600miles of track day
- no problem.
Now 500miles later it is starting to act up again.
When cold OK.
Warm up and drag.
Can't spot leaks either.
