side repeater removal
what is the process for removing the side repeaters? i am guessing it is too carefully insert a flat blade screw driver, but where do you inset it, and what are the pit falls?
thanks
Re: side repeater removal
on most you push either forward or backward on the repeater and lift the end opposite to the direction, I.E.
if you push tward the front lift the rear edge and vise versa
MartG wrote:Remove the arch liner and then you can get at the clips from behind
I did this to save marking the wing, alot easier and safer this way
